Is it possible to have the description of a product styled like how it’s shown in the link below? So basically, I’m trying to find a way for the description to be moved under the product title and afterwards I can style the description text. I’ve been trying to go through the code base to figure where the description field is located, but I can’t seem to locate it. If you happen to know where in the code base I could possibly achieve what’s in the image below for the description I would really appreciate it.
Would you happen to know if it’s possible to style the markdown in the invoice editor? If there was some way to target the different headings from the style tab in the invoice editor that would be great.
