Problem with queue
Version ie v5.13.53
Environment Shared Hosting
Checklist
Describe the bug
Open Jobs: 2315
Failed Jobs: 7
Steps To Reproduce
Expected Behavior
Additional context
Screenshots
Logs
Exception: cURL error 52: Empty reply from server (see libcurl - Error Codes) for https://pdf.invoicing.co/api/ in /html/invoiceninja-5/app/Services/Pdf/PdfService.php:106
Stack trace:
#0 /html/invoiceninja-5/app/Jobs/Entity/CreateRawPdf.php(106): App\Services\Pdf\PdfService->getPdf()
#1 /html/invoiceninja-5/app/Mail/Engine/InvoiceEmailEngine.php(132): App\Jobs\Entity\CreateRawPdf->handle()
#2 /html/invoiceninja-5/app/Jobs/Entity/EmailEntity.php(160): App\Mail\Engine\InvoiceEmailEngine->build()
#3 /html/invoiceninja-5/app/Jobs/Entity/EmailEntity.php(103): App\Jobs\Entity\EmailEntity->resolveEmailBuilder()
#4 /html/invoiceninja-5/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php(36): App\Jobs\Entity\EmailEntity->handle()
#5 /html/invoiceninja-5/vendor/laravel/framework/src/Illuminate/Container/Util.php(41): Illuminate\Container\BoundMethod::Illuminate\Container{closure}()
#6 /html/invoiceninja-5/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php(93): Illuminate\Container\Util::unwrapIfClosure(Object(Closure))
#7 /html/invoiceninja-5/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php(35): Illuminate\Container\BoundMethod::callBoundMethod(Object(Illuminate\Foundation\Application), Array, Object(Closure))
#8 /html/invoiceninja-5/vendor/laravel/framework/src/Illuminate/Container/Container.php(662): Illuminate\Container\BoundMethod::call(Object(Illuminate\Foundation\Application), Array, Array, NULL)
#9 /html/invoiceninja-5/vendor/laravel/framework/src/Illuminate/Bus/Dispatcher.php(128): Illuminate\Container\Container->call(Array)
#10 /html/invoiceninja-5/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(144): Illuminate\Bus\Dispatcher->Illuminate\Bus{closure}(Object(App\Jobs\Entity\EmailEntity))
#11 /html/invoiceninja-5/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(119): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline{closure}(Object(App\Jobs\Entity\EmailEntity))
#12 /html/invoiceninja-5/vendor/laravel/framework/src/Illuminate/Bus/Dispatcher.php(132): Illuminate\Pipeline\Pipeline->then(Object(Closure))
#13 /html/invoiceninja-5/vendor/laravel/framework/src/Illuminate/Queue/CallQueuedHandler.php(123): Illuminate\Bus\Dispatcher->dispatchNow(Object(App\Jobs\Entity\EmailEntity), false)
#14 /html/invoiceninja-5/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(144): Illuminate\Queue\CallQueuedHandler->Illuminate\Queue{closure}(Object(App\Jobs\Entity\EmailEntity))
#15 /html/invoiceninja-5/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(119): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline{closure}(Object(App\Jobs\Entity\EmailEntity))
#16 /html/invoiceninja-5/vendor/laravel/framework/src/Illuminate/Queue/CallQueuedHandler.php(122): Illuminate\Pipeline\Pipeline->then(Object(Closure))
#17 /html/invoiceninja-5/vendor/laravel/framework/src/Illuminate/Queue/CallQueuedHandler.php(70): Illuminate\Queue\CallQueuedHandler->dispatchThroughMiddleware(Object(Illuminate\Queue\Jobs\DatabaseJob), Object(App\Jobs\Entity\EmailEntity))
#18 /html/invoiceninja-5/vendor/laravel/framework/src/Illuminate/Queue/Jobs/Job.php(102): Illuminate\Queue\CallQueuedHandler->call(Object(Illuminate\Queue\Jobs\DatabaseJob), Array)
#19 /html/invoiceninja-5/vendor/laravel/framework/src/Illuminate/Queue/Worker.php(439): Illuminate\Queue\Jobs\Job->fire()
#20 /html/invoiceninja-5/vendor/laravel/framework/src/Illuminate/Queue/Worker.php(389): Illuminate\Queue\Worker->process(‘…’, Object(Illuminate\Queue\Jobs\DatabaseJob), Object(Illuminate\Queue\WorkerOptions))
#21 /html/invoiceninja-5/vendor/laravel/framework/src/Illuminate/Queue/Worker.php(176): Illuminate\Queue\Worker->runJob(Object(Illuminate\Queue\Jobs\DatabaseJob), ‘…’, Object(Illuminate\Queue\WorkerOptions))
#22 /html/invoiceninja-5/vendor/laravel/framework/src/Illuminate/Queue/Console/WorkCommand.php(137): Illuminate\Queue\Worker->daemon(‘…’, ‘…’, Object(Illuminate\Queue\WorkerOptions))
#23 /html/invoiceninja-5/vendor/laravel/framework/src/Illuminate/Queue/Console/WorkCommand.php(120): Illuminate\Queue\Console\WorkCommand->runWorker(‘…’, ‘…’)
#24 /html/invoiceninja-5/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php(36): Illuminate\Queue\Console\WorkCommand->handle()
#25 /html/invoiceninja-5/vendor/laravel/framework/src/Illuminate/Container/Util.php(41): Illuminate\Container\BoundMethod::Illuminate\Container{closure}()
#26 /html/invoiceninja-5/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php(93): Illuminate\Container\Util::unwrapIfClosure(Object(Closure))
#27 /html/invoiceninja-5/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php(35): Illuminate\Container\BoundMethod::callBoundMethod(Object(Illuminate\Foundation\Application), Array, Object(Closure))
#28 /html/invoiceninja-5/vendor/laravel/framework/src/Illuminate/Container/Container.php(662): Illuminate\Container\BoundMethod::call(Object(Illuminate\Foundation\Application), Array, Array, NULL)
#29 /html/invoiceninja-5/vendor/laravel/framework/src/Illuminate/Console/Command.php(211): Illuminate\Container\Container->call(Array)
#30 /html/invoiceninja-5/vendor/symfony/console/Command/Command.php(326): Illuminate\Console\Command->execute(Object(Symfony\Component\Console\Input\ArgvInput), Object(Illuminate\Console\OutputStyle))
#31 /html/invoiceninja-5/vendor/laravel/framework/src/Illuminate/Console/Command.php(180): Symfony\Component\Console\Command\Command->run(Object(Symfony\Component\Console\Input\ArgvInput), Object(Illuminate\Console\OutputStyle))
#32 /html/invoiceninja-5/vendor/symfony/console/Application.php(1096): Illuminate\Console\Command->run(Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
#33 /html/invoiceninja-5/vendor/symfony/console/Application.php(324): Symfony\Component\Console\Application->doRunCommand(Object(Illuminate\Queue\Console\WorkCommand), Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
#34 /html/invoiceninja-5/vendor/symfony/console/Application.php(175): Symfony\Component\Console\Application->doRun(Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
#35 /html/invoiceninja-5/vendor/laravel/framework/src/Illuminate/Foundation/Console/Kernel.php(201): Symfony\Component\Console\Application->run(Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
#36 /html/invoiceninja-5/artisan(35): Illuminate\Foundation\Console\Kernel->handle(Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
#37 {main}
To start I suggest checking in the database to ensure these are recent errors.
According to the “jobs” table, all the entries are old, from August 2026.
How can I clear the error list?
php artisan queue:clear
php artisan queue:flush
Sorry, but it was not helpful
Try:
php artisan queue:work database --queue=scout
That was somewhat helpful.
The pending jobs have now been cleared, but there are still 7 failed jobs.
Stack trace:
#37 {main}
I’m not sure, one workaround is to manual clear the failed_jobs table.
The deletion was successful, and everything still seems to be working. In any case, the system check looks good now—thank you very much.
Awesome, glad to hear it!
