Problem with invoice layout after update to 5.10.23
Version ie <v5.10.23>
Environment
Checklist
  • Can you replicate the issue on our v5 demo site https://demo.invoiceninja.com or Invoice Ninja? no
  • Have you searched existing issues? yes
  • Have you inspected the logs in storage/logs/laravel.log for any errors?
Describe the bug
After updating, my invoices have a problem with the layout (see attached file), it’s little and the CSS code is showing on the page.
Ps. I didn’t change any other information/configuration in the app.
Screenshots
Can someone help me?
I suggest asking in a discussion on GitHub
Hi @hillel ,
Sorry, but, you don’t help by here anymore?
I don’t understand this kind of system, there’s 2 forums and I need to find the good one to post the bugs?
We use the support forum (and Slack/Discord) to provide support for features in the app. We use GitHub to track bugs in the app which this appears to be.
Is this maybe about an qr-code?
I don’t think the problem is directly to the qr-code, because it works when I put back the version 5.11.6 and it always worked.
No, what I mean is, if this long code replaces a sepa-qr-code which was shown before. There’s a new way to make qr-codes visible:
https://github.com/invoiceninja/invoiceninja/discussions/10473
Is the sepa-qr-code the same as the swiss-code?
In general, yes:
Taken from the updated manual-website.
The “data-state”-part is needed to print the qr-code.
You saved my ass - thx Schmitti!
data-state=“encoded-html” did the trick…
Thanks.
That worked.
Now I need to arrange the position of the Qr-code because I use it on second page and at first I already had some problems to do it.
Thanks again.
Do I understand you correctly that you want to have the QR-code always be drawn on a single last page? This should be possible by using the css-code break-before: always; – I think. I’m no coder, so I have to guess.
However, this should look like the following, if I’m thinking rightly now:
<head>
<style>
.sepa-qr-code {
</style>
</head>
<html>
  <div class="sepa-qr-code" data-state="encoded-html">
    $swiss_qr
  </div>
</html>
