Hello, I have been using Android app since a long time. But after the update since 2 months I have been experiencing a problem. When I click Invoices or Quotes menu in the right, it keeps loading and won’t show anything. While all the other menus like Projects, Items or Clients work perfectly well.
Is anything I should know that fix the problem?
Which exact versions of the web and mobile app are you using?
Web: 4.5.17
App: 0.1.57
It may help to update to the latest version of the web app
Done! Updated to 4.5.19 but the same problem with the app…
I can see in the first page of the app that 2 fields keep loading too…
Sorry, I’m not sure. If you want to add [email protected] as a user I can try to debug it.
I don’t think it’s related to those settings
