Problem mit Stundensätzen
Hello Togather!
Version ie v5.13.36
Environment
self hosted without docker
Describe the bug
Although a standard hourly rate is defined, it is not carried over into the time tracking:
Steps To Reproduce
Create a time entry; the hourly rate is applied initially:
But if i choose a Customer it flips to empty:
Expected Behavior
The hourly rate field remains populated with the standard hourly rate.
Is it a bug or is there new Config option?
Thanks in Advice,
Timo
It looks like you’re using the web app, you may want to compare with the desktop/mobile apps.
Feel free to create an issue on the web app GitHub repo to report this:
