I would need your help in knowing if the quotes, invoices payments which i have marked as deleted in my account can be purged?
These are affecting the reports i am generating and i would like to know how this can be done.
I have a few in deleted state for quotes, invoices and payments. Few i did when i started playing around with the tool.
TIA
July 26, 2023, 1:48pm
There is a setting on Settings > Account Management to exclude deleted records from reports.
The app doesn’t support purging a single invoice.quote however if you purge the client it will also purge their records.
Hi
I only see the following options.
What should i change to exclude deleted records?
TIA
Just noticed that you were referring to the invoicing.co webpage option. But this is not there in app.invoicing.co
Me and my team are using the app.invoicing.co .
When would this be made available in this domain?
TIA
July 26, 2023, 2:08pm
5
You are correct. We can’t provide an ETA but we’ll add this to our list.
cc @david
david
July 27, 2023, 6:06am
6
@vignesh.ramji23
By default you should not be seeing deleted records in the records from the react app. Are you seeing otherwise?
I am seeing deleted payments in an exported report for invoices. I had done some for trial purpose at the start, to understand how this software works.
david
July 27, 2023, 10:36pm
8
@vignesh.ramji23
I see the issue here, checking in a fix.
