I have self-hosted installed with three companies created.
I have three domains pointed at the installation, and I would like to use one domain per company.
This seems to work fine if I login at the correct domain at the beginning. For example, if I login to company1.com and send out invoices from Company 1, it will use that URL in my invoices, client dashboard, etc. However, if I switch to Company 2 while logged in to company1.com, it still uses company1.com on invoices and links.
Is it possible to configure multiple domains in the .env file, similar to the way that it already can configure multiple mail configurations for each company?
Hi there,
very old thread but is there any new info about this? Looking for this as well: have different companies in one self-hosted installation and would like to use different urls for each company.
I have mapped 2 different domains to my setup procedure which already allows me to trigger the setup via these domains in the same installation.
So, any update on this?
Thanks and kind regards,
charismeki
Is this for the clients of the company? I am more asking about the company domain. So invoice ninja in a multi domain setup for my 2 companies would be the aim. I would like to have fibu.c1.com fibu.c2.com
with different customer, team members etc in the same installation…
Possible?
