Hopefully this is the right place to address my question. I am a little overwhelmed with all the information on userguide, github, and forum. Seems to me a little like a flea circus. Chapeau and Merci for your great work!
(1) Is it possible to create e-mails generally in plain text?
Thats what i would prefer. I am a bit oldschool and don´t like the HTML-ChiChi in mails
(2) BTW … as found here
i expected to find a WYSIWYG Edi(t)or then to customize mails, but … nope. Is there the need to install some additional package on my underlaying debian 11.8 (and IN v5.8.33-C156)? Or ist the WYSIWIG editor only available in the native apps? I am using the WebUI.
Thanks in advance for your response.
Best regards from Berlin!
You can remove the HTML design by selecting the custom email design on Settings > Email Settings
All apps support a WYSIWYG editor if it’s enabled on Settings > Account Management. The Flutter app requires you to select the text to see the formatting options, I suggest trying the React app to compare.
I was fiddeling around this weekend. Comparision between Flutter and React WebUI has given me insights, but …
(2) When changing Settings > Email Settings to “custom” there will appear no e-mail-signature in the generated e-mails anymore. Is this a bug or a feature?
(1) So i changed back to “plain” again and formatted the text to “preformatted” which results nearly to the wanted plain-text design. But neither “custom” nor “plain” generates e-mails with “Content-Type: text/plain”. Content-Type is now multipart/mixed. I guess this might be because of the very last IN recommendation line? Will the white label subscription solve this too?
