I have recently upgraded from a bug version to the version 5.3.66.
It was an ugly upgrade process and I had to manually import many of the tables, one by one because the database schema was different from my previous installation version. I am only saying it because it may be a clue of my current problem.
My new installation works beautifully, when the QUEUE_CONNECITON in .env is set to sync. Once I change to database it does not send any email.
I have tried to listen tot he queue and this is what I get.
root@billing .../www/ninja# sudo -u www-data php artisan queue:listen
In Connection.php line 712:
SQLSTATE[HY000] [2002] Connection refused (SQL: select * from information_s
chema.tables where table_schema = ninja and table_name = accounts and table
_type = 'BASE TABLE')
In Connector.php line 70:
....(repeating)
I would love to solve this problem. Would you know what is wrong?
