Version 5.11.7
Environment Zip
Describe the bug
PDF wil not show up and it doenst load
Can you please share a screenshot of the health check dialog?
i did use first snappdf but that was also not working and my crons are normaly set so i don’t now why that is
Are there any related errors in the logs?
Also, have you tried the web app?
Have you checked both the browser console and storage/logs for any related errors? Without any error details it’s hard to help.
where can i find the errors in the web gui?
i found something interesting it loads the pdf but like after 1 a 3 mins
Which PDF renderer are you using?
first snappdf and then the default one of invoice self but they are both slow
I suggest asking in a discussion on GitHub
i found it! The vm where invoice ninja whas on it has a strict network so evrey time that i ask for a pdf blocked the system it. So now it is not on a strict network ![]()
