I upgraded from v5.3.68 to v5.3.73-C77, and the PDF size change to 21.587cm x 27.937cm (i.e. presumably sticks on Letter size @ 8.5 x 11 inches) even though A4 was chosen:
Guys, sorry, but you can’t do that. It breaks so much and A4 is the most widely used paper format:
Most countries in Europe and Asia use an international standard known as the A-series. A4, for example (297 x 210 mm) is slightly longer and narrower than the 8 1/2 x 11 inch letter size (279 x 216 mm) commonly used in the US and Canada. ) .
Just because something caused issues, don’t just drop it from the software. Fix the code, not the surroundings. You cannot ask Invoice Ninja users (which are mostly non-tech) to add some CSS to a design.
@david@hillel I kindly ask you to think about this regression again.
I have not try yet, but I am concern about needing to change the CSS and save as a custom design. May I know how did the $page_size option caused issue?
Is there any chance that it will be fixed in the upcoming release so that no workaround is needed?
