I purchased the white label license and use the design “calm”.
Whenever I add to many items to my invoice, an automatic page break happens as intended.
But text directly continues on the second page, without any distance to the top of the page…
Example of a second page can be found here: https://imgur.com/a/4TYoEFc
How can I add some spacing to the top of following pages?
Thank you in advance!
Florian
Same happens when using the original “Calm” Design, it does not depend on the background picture.
I need to define some kind of offset to the top of following/second pages…
This could also be a header with a couple of line breaks, that is only applied to following pages… just an idea…
@page {
margin-left: 0cm;
margin-right: 0cm;
margin-top: 2cm;
margin-bottom: 0cm;
size: $page_size $page_layout;
@page :first {
/* You can only change the size, margins, orphans, widows and page breaks here */
/* Paper size and page orientation */
size: A4 portrait;
/* Margin per single side of the page */
margin-left: 0cm;
margin-top: 0cm;
margin-right: 0cm;
margin-bottom: 2cm;
