It worked in the beginning but it stopped whithout any explanation.
In the log of “laraval.log” I can see this message.
production.ERROR: There was an error generating the PDF with Phantom JS {“exception”:"[object] (App\Exceptions\PhantomPDFFailure(code: 0): There was an error generating the PDF with Phantom JS at /home/public_html/invoice/app/Utils/PhantomJS/Phantom.php:150)
I dont think I did a 100 pdf in less than an hour. But I will create a key.
That said it is the morning after and still have error messages about the PDF.
im using the free API key for 500 PDFs per day for a while now and i think that they dont calcutale like 100 PDFs =100PDFs, they remove the number of PDFs from your daily allocation depending on how much time or how much bandwidth or size of your PDF, IM NOT SURE WHICH COMBINATION IF NOT ONLY 1 APPLIES, i have actually seen that they can remove 28 from your daily allocation after you have previewed just 1 PDF, may anyone who knows better correct me here.
Remember: When creating an invoice you will see the preview of the invoice being updated with every tiny little change you make, a second or two after you stop typing. You can see the updating at the top end of the preview (the blue, moving slider). Every such update counts towards your allowance.
To be honest. The 500 can go very quick when you try to write an invoice.
Is it possible to disable the preview or only have show on command when writing an invoice ?
The Free Plan provides a Daily Subscription of 0.05 Credits. Using an average Page Cost of 2 seconds and 50Kb, this equals 500 Pages/Day. If each page you request takes more time/data, then you will get fewer than 500 Pages/Day. If your pages take less time/data, then you will get more than 500 Pages/Day.
Thank you so much for that Clarification, i kind of knew iw works that way but dont know the correct way to put it, ONE THIN I HAVE DONE TO VERIFY AND SEE FOR MYSELF HOW THAT AFFECTS MY PDF DAILY LALLOCATIONWAS:
i logged into my free account at Phantomjs website, and i press the refresh button, i then go to my invoice ninja and view an invoice, i then switch tabs and check the old number then refresh and compare the number deducted, THIS GAVE ME A BIT OF CAUTIOUSNESS NOW THAT I KNOW HOW MUCH IS REMOVED EACH TIME I VIEW.
does a Free alternative exist for V5 self hosted whitelabel? i have read about SnapPDF but then im using cPanel, or should open a new topic on this?
For some reason. I am getting this screen when trying to view the invoice. I can’t download the invoice and clients can’t see the invoice as well. It’s like the pdf is corrupt:
