PDF Generator Formatting
I was wondering of a way to let the system know that if the items bleeds onto next page to insert page break at between items or between totals. Not just middle of the totals…
right now it’s
Last item
Subtotal
Page Break
Tax
Discount
Total
I’d prefer
LAST ITEM
Pg Break
totals
pg 2 only has 3 items… better yet auto scale if under a certain amount of lines…
@SSP
Which design are you using? I believe the clean design will work the way you expect.
If you are using something like the Plain design, they you may see the behaviour you are describing. This can be resolved by creating a custom design based off the plain design.
Then in the Includes section find this block:
#table-totals {
        margin-top: 0rem;
        display: grid;
        grid-template-columns: 2fr 1fr;
        padding-top: 0rem;
        padding-right: 1rem;
        padding-left: 1rem;
        gap: 80px;
        page-break-inside:auto;
        overflow: visible !important;
and change the
line to
page-break-inside: avoid;
