hey @ben
Thanks for your reply!
I tried php artisan migrate:
* Application In Production! *
Do you really wish to run this command? (yes/no) [no]:
> y
Nothing to migrate.
Hi @ben
Would it help if I give you access to one of my IN installations?
I can replicate it on two completely different installations on different hosters, so I assume it’s definitely a bug…
Edit: I was able to fix it. I had to re-create my custom template, then it worked with the same code.
