PDF Generation Fails with Signal "6" in Invoice Ninja v5 – Need Help!
Hi everyone,
I’ve been banging my head against the wall trying to get PDF generation to work in Invoice Ninja v5. All dependencies for snappdf are installed (i guess…), but every time I try to open the invoice preview, I get hit with an error 500.
Running the snappdf test command results in
The process has been signaled with signal "6".
Here’s what I’ve tried so far:
  • All the required libraries are installed
  • Increased PHP memory limits (currently at 16G)
  • Downloaded snappdf with the invoiceninja helper
  • Googled and read almost all websites regarding snappdf
Nothing has worked, and I’m out of ideas. What’s even more frustrating is the idea that I might need to install a full X stack on a web server just to get PDFs working! This seems absolutely ridiculous—why does a simple PDF generation require thousands of libraries and graphical components? It’s a web server, not a desktop!
Does anyone have a proper fix for this, or maybe a workaround that doesn’t involve installing a ton of unnecessary packages? I feel like this should be way simpler than it is.
Any help or advice would be greatly appreciated!
debian 12, php-fpm 8.2
Seriously, Invoice Ninja is great, but setting up PDF generation is a nightmare. Why does it have to be this hard?
For everyone with the same issue, make
/vendor/beganovich/snappdf/versions/1363277-Linux_x64/chrome-linux/chrome_crashpad_handler
executable.
Nice that such important stuff is documented somewhere. Not.
for someone who not always on shell
chmod +x vendor/beganovich/snappdf/versions/1426116-Linux_x64/chrome-linux/chrome_crashpad_handler
