PDF Custom Design with multi currency
I need to custom design my PDFs in order to print my invoices.
I need to add an extra column to the TOTAL BOX, with the only difference that I need to multiply the Subtotal, Taxes and Total by the Exchange rate in order to have the multi currency.
Where can I edit or create a new Invoice template in order to do this??? (I could duplicate a current template and edit from there, but not sure where is the directory)
Any sugestions?
One option may be to create a template
Ok I think Im doing Okey following the steps with a custom template.
Quick question:
Is the documentation from Free Source Available Invoicing, Expenses & Time-Tracking | Invoice Ninja updated?
Im getting errors while using this selectors.
For example:
When trying to get $total_taxes I get the following result: $10,00_taxes
Any ideas why?
@david can you please advise?
Can you post the snippet you are using?
you would need to be using the twig variable invoice.total_taxes
the $ variable $total_taxes does not exist
