When I enter a payment an email is send to the client. But this email is not correct. the number of the invoice is not correct and also not the view button is show. Athough the email I receive Is correct
So this is my template data
$client,
Bedankt voor uw betaling van $amount voor factuur $number
$viewButton
The preview looks fine
But the client receive this
while I receive this
But I also get the following email or is this because I set the > dev info
February 25, 2022, 11:31am
I think the problem is that for the payment email $number will be the payment number.
I believe you can $invoice for the invoice number instead.
$viewButton was indeed wrong. But $invoice I don’t see this in the field below. Only $number. but the preview is ok
but I will try with $invoice
February 25, 2022, 12:12pm
5
Sorry, I believe it’s $invoices with an ‘s’
hillel:
$invoices
$invoice is correct. Still don’t know why I get sometimes the cron job error
February 25, 2022, 12:18pm
7
Thanks for the update!
Is the cron set to run every minute?
February 25, 2022, 12:30pm
9
To clarify… are you saying you sometimes see the red triangle error in the app saying the cron needs to be enabled?
February 25, 2022, 1:23pm
11
Which error are you seeing?
Was in an email that I got the message
February 25, 2022, 1:54pm
13
Can you share a screenshot or the exact error message?
March 20, 2022, 9:33am
15
david
March 20, 2022, 9:45am
16
Looks like the command isn’t being run by the system. I would check with your host? Perhaps they are blocking ?
