Hi guys, I am working on integrating with Payfast, their dashboard has changed quite a bit since the last time I’ve used it.
Where could I find a PDT Key? And where would I find the PayFast “Notify URL”?
My installation is currently live on https://portal.webmeta.co.za
@david @ben do you know?
@Webmeta
We bake in the notifyURL into the code so you do not need to worry about this field. I think the PDT isn’t a critical field and may be used elsewhere? From my tests, the API works without this field.
Perfect, thanks for you swift feedback. Really loving this product of yours.
