As this is a great software i recommend the self host to a client of mine, he loved the look of it but i am having an issue with it.
I have just installed a fresh install on the server and getting this error -
Parse error: syntax error, unexpected '$value' (T_VARIABLE) in /home/vqmokcct/(removed to protect client identity)/vendor/aws/aws-sdk-php/src/functions.php on line 36
The only cause for the issue we’ve seen is the PHP version.
Sometimes the server is configured with two separate PHP versions: one for the web server and one for the CLI. You may want to create a phpinfo page to check.
