Hi fellow Invoice Ninjas, Hi Hillel (I guess you’re reading this),
we’ve been doing some custom designs lately and everything works well.
But we’ve found ourselves stuck with an issue regarding the limitations of invoice ninja, since we serve different customer groups and use different Designs for each of them, we ended up with more than 3 Designs. I already knew that there is no way to add more than 3 Custom Designs so I figured out we could just override the default ones using the MySQL table invoice_designs, which didn’t affect anything at all.
Which I’ve found odd since I am able to update the Custom Themes in the account table using MySQL.
So is there anyway to replace the default themes, I mean they need to be stored somewhere and if they do I could replace them. Or any other possible workaround ?
Makes sense, it took me a afternoon to get the whole pdfmake syntax right and html and css is kind of the common standard.
Ohh btw is there a way to rename the standard themes, it’s not necessary, I mean I could deal with it if not, but it would be kinda nice just to make it easier to find the design needed. Thanks for your help so far!
