I need help getting online payments out of test mode, please.
Which payment gateway are you using?
Some have a ‘test mode’ option when editing the gateway settings on Settings > Online Payments > Gateways
Hi there,
I am using Stripe and for the life of me, I can’t figure out how to get it out of test mode. The option isn’t there going to Settings > Online Payments > Gateways nor under settings once I’m in there.
you’ll want to use production API keys, it sounds like you are using test keys
Is there a way to switch Stripe over to the testing API keys? I can’t find that when looking at the Stripe Connect gateway… everything seems to be done via oauth and set to “live” with no obvious way to use “testing” when integrating Stripe…
We’ve enquired with Stripe on this. Unfortunately it isn’t possible to selectively put some accounts into Test mode…
