I have already reported this via email only to be told to do what I have already reported as the issue, so I’m turning to you for guidance.
Since the most recent update 5.0.57 no matter what I have in Invoice Design > General Settings, or even go to Client level then Choose Invoice Design > General Settings (which is supposed to override system-wide settings) I still get the same result - a color pair not of my choosing on all generated invoices.
No matter what I have done in the app or via Chrome the PDF generator is still producing the same result. Is it at all possible that your server-side PDF generator program is somehow coded to use these colours???
I’m not able to recreate this either, i Can see one of the designs that uses headers and footers doesn’t change colors, but the other designs do respond to the highlight color changes.
I create a new invoice - even with different clients - it always uses colours not of my choosing.
I have used Chrome and Safari and flushed the cache
I have deleted and reinstalled the app on iOS
I have deleted and reinstalled the app on MacOSX
The only way I finally overcame this was to create my own invoice scheme based on a different template to the one I had been using. Because I had tried so many fixes at the Client > Settings level I had to update every client to use the new invoice template because there is NO option to remove a setting - only to choose another template.
That means that is any client has had special settings applied and you wish to revert to the standard Settings should there not be functionality - in the same manner as the “Edit Client” screen with an X to remove a selection or to offer a Reset Client Settings option??
Still love the product and really hope that you guys will go on to make it even better.
Thank you but I am a hosted user, not self-hosted. I have always ensured I am updated and am most recently using 5.0.57 - anyway as last message explained by creating my own template I appear to have resolved the issue.
However with the new version and its far wider scope for individuality for clients, there should be an option to apply a setting to a group or to all instead of having to manually visit every client and even then every outstanding invoice. For example, if a user wants to apply an update to a client it should not then be necessary to then have to manually update every outstanding invoice in order to mail out receipts with the updated style or fields etc.
