Not possible to change Taxes Settings
Hello together,
I played around with invoice ninja.
On my first installation I had trouble with viewing and generating pdf which I solved with several reinstalls.
I don’t really know what the problem was.
But for now my biggest problem ist that it’s impossible to change the settings in Taxes.
None of the checkboxes are usable.
What I exactly mean is marked in the red box oof the screenshot.
Any suggestions on what I can do to solve it?
@david @ben can you please advise?
Note: you may also want to test with the desktop app.
@hillel
Invoiceninja is installed on docker with docker-compose.
The docker app supports the desktop/mobile apps.
@hillel
I see it, glad I’m very surprised of it :wink:
Let me play with it, I will give a feedback when finished.
But at the moment this fixed my problem and now I have the old problem I described (pdf related) back :frowning:
but one question to the desktop app:
in the app it’s possible to change this setting.
But in the Browserapp (doesn’t matter which one on Mac) it’s not.
Could you explain this behaviour?
It should work across all apps, if you’re seeing a problem feel free to create an issue on GitHub.
