ymadriz
September 25, 2018, 6:27pm
1
I am using the self hosted version of IN but I don’t seem to be able to do the following with a PUT call, if I do a POST with the same information, I am able to create a new invoice:
curl -X PUT
http://yoalmadriz.com/ninja/public/api/v1/invoices
-H ‘Cache-Control: no-cache’
-H ‘Content-Type: application/json’
-H ‘Postman-Token: 181c82f0-698a-48a1-ae3a-3d17d98986ae’
-H ‘X-Ninja-Token: mytoken’
-H ‘X-Requested-With: XMLHttpRequest’
-d ‘{
“id”: 2,
“client_id”: 1,
“public_notes”: “hola”
There is nothing in the error log, I get 405 METHODNOTALLOWED in Postman and a page ‘Whoops, looks like something went wrong.’. My version is 4.5.4.
Are there any restrictions for PUT in the sefl hosted version? Do I need to provide any special set of data? I also tried with id only and did not work.
Thanks!
September 25, 2018, 6:29pm
A put request would need to include the id in the URL, ie. api/v1/invoices/1
ymadriz
September 25, 2018, 6:41pm
3
Thanks for the quick response, I just tried it with the id in the URL and I got Internal Server Error and the following in the error log:
[2018-09-26 04:36:22] production.ERROR: ErrorException [0] : /home/bhokp8bj6m4e/public_html/ninja/app/Ninja/Repositories/InvoiceRepository.php [Line 545] => Undefined index: invoice_items {“context”:“PHP”,“user_id”:1,“account_id”:“1”,“user_name”:“Yoal Madriz”,“method”:“PUT”,“user_agent”:“PostmanRuntime/7.3.0”,“locale”:“en”,“ip”:“186.32.177.243”,“count”:1,“is_console”:“no”,“is_api”:“yes”,“db_server”:“mysql”,“url”:“api/v1/invoices/2”} []
And I know the invoice ID is valid because if use GET with the same URL you just gave me, it works.
September 25, 2018, 6:48pm
4
To update an invoice you need to send the current data, you’re seeing the error because you aren’t sending invoice_items.
ymadriz
September 25, 2018, 6:56pm
5
You are a genius, that made the trick, thanks a lot for your support! Greetings from Costa Rica!!!
September 25, 2018, 7:13pm
6
Glad to hear it’s working!
Are you able to provide the full code that you got this to work with?
