aaron
1
first the windows app, now the android app.
when a customer pays ahead i need to be able to enter the payment, then apply it to next months invoice when generated.
in either app, when creating a new payment there is no where to enter an amount.
both older verions that had the amount worked fine. make the old versions available if you are going to take features away.
You can enable the “apply payments later” option on Settings > Payment Settings to reenable the feature.
aaron
3
found that setting, when i change it and apply. it says it saved setting, but then the slider goes back to off when it saves.
4
I think you may need to update the backend app to the latest version.
