I have two different URLs for InvoiceNinja, erp.example.com for Admin access and cp.example.com for the client portal. After setting the APP_URL to https://cp.example.com in .ENV file, I am getting the following error:
Access to fetch at ‘https://cp.example.com/canvaskit/canvaskit.wasm’ from origin ‘https://erp.example.com’ has been blocked by CORS policy: No ‘Access-Control-Allow-Origin’ header is present on the requested resource. If an opaque response serves your needs, set the request’s mode to ‘no-cors’ to fetch the resource with CORS disabled.
I have billing.mydomain.com and also an alias domain billing.mydomain.net.au pointing to my invoiceninja install.
billing.mydomain.com works fine but billing.mydomain.net.au produces this CORS policy error and doesn’t load certain elements, such as the logo. @hillel@david Any thoughts?
Yes the desktop app works. I have moved my domain from x.net.au to x.au. In order to respect links that clients have received from Invoice Ninja in their email, I have configured invoice ninja for x.au but also set up the alias domain .net.au for this reason, however I get the issue mentioned above. This might not affect the client portal…I haven’t fully checked yet but I’m concerned certain elements won’t load properly under the .net.au.
