OK, I have I moved IN on to a new server using docker. Everything works now EXCEPT PDF generation. It is similar to this thread in that the env app_url and the docker .yaml url are somehow out of alignment giving me http errors over https in the browser console. Does anyone have a hint on how the .yaml url & the .env should be populated? Or should I try to set up Nginx on the container to connect securely instead of the current port of 8081?
It may help to set LOCAL_DOWNLOAD=true in the .env settings
Setting LOCAL_DOWNLOAD failed to fix it as I am still getting the same error:
main.foss.dart.js?v=5.3.29:77624 Mixed Content: The page at 'https://inv5.myriad.ca/#/' was loaded over HTTPS, but requested an insecure XMLHttpRequest endpoint 'http://inv5.myriad.ca/client/invoice/jBbAUUqUfsbOy4DX6mOXWi5z4iVf2pQj/download?t=1635619229925&per_page=999999'. This request has been blocked; the content must be served over HTTPS.
I am using Apache to proxy the http from Nginx from the container…
Can you check the APP_URL value is using HTTPS and not HTTP
Nah, same error. It’s funny - when I click "Delivery Note’ the pdf appears!
@david do you have any ideas?
Do you have TRUSTED_PROXIES=* configured in your env file?
I love you David, you too Hillel - it was your LOCAL_DOWNLOADS and the TRUSTED_PROXIES that fixed it! It works - finally. Never give up, never surrender!
One last question. How can I import my data from the broken V5 version to this new Docker version?
Glad to hear it’s working! Maybe you can use the JSON import/export?
