when i set php 7.3.33 then i get “ERR_TOO_MANY_REDIRECTS”
PHP info
PHP Version 7.3.33
System Linux web0101.zxcs.nl 3.10.0-962.3.2.lve1.5.61.el7.x86_64 #1 SMP Wed Aug 18 07:50:15 UTC 2021 x86_64
Build Date Jan 26 2023 20:42:43
Configure Command './configure' '--disable-dependency-tracking' '--prefix=/usr' '--exec-prefix=/usr' '--bindir=/usr/bin' '--sbindir=/usr/sbin' '--sysconfdir=/etc' '--datadir=/usr/share' '--includedir=/usr/include' '--libdir=/usr/lib64' '--libexecdir=/usr/libexec' '--sharedstatedir=/var/lib' '--mandir=/usr/share/man' '--infodir=/usr/share/info' '--build=x86_64-redhat-linux-gnu' '--host=x86_64-redhat-linux-gnu' '--target=x86_64-redhat-linux-gnu' '--program-prefix=' '--prefix=/opt/alt/php73' '--exec-prefix=/opt/alt/php73' '--bindir=/opt/alt/php73/usr/bin' '--sbindir=/opt/alt/php73/usr/sbin' '--sysconfdir=/opt/alt/php73/etc' '--datadir=/opt/alt/php73/usr/share' '--includedir=/opt/alt/php73/usr/include' '--libdir=/opt/alt/php73/usr/lib64' '--libexecdir=/opt/alt/php73/usr/libexec' '--localstatedir=/var' '--sharedstatedir=/usr/com' '--mandir=/opt/alt/php73/usr/share/man' '--infodir=/opt/alt/php73/usr/share/info' '--cache-file=../config.cache' '--with-libdir=lib64' '--with-config-file-path=/opt/alt/php73/etc' '--with-config-file-scan-dir=/opt/alt/php73/link/conf' '--disable-debug' '--enable-calendar' '--enable-exif' '--enable-ftp' '--enable-huge-code-pages' '--enable-opcache' '--enable-opcache-file' '--enable-shmop' '--enable-unicode' '--enable-xml' '--with-bz2' '--with-freetype-dir=/usr' '--with-gettext' '--with-gmp' '--with-iconv' '--with-jpeg-dir=/usr' '--with-layout=GNU' '--with-libxml-dir=/opt/alt/libxml2/usr' '--with-mhash' '--with-password-argon2=/usr' '--with-pcre-jit' '--with-pcre-regex' '--with-pic' '--with-png-dir=/usr' '--with-readline' '--with-t1lib=/opt/alt/t1lib/usr' '--with-webp-dir=/opt/alt/libwebp' '--with-xpm-dir=/usr' '--with-zlib' '--with-zlib-dir=/usr' '--without-gdbm' '--without-pear' '--with-curl=/opt/alt/curlssl11/usr' '--with-openssl-dir=/opt/alt/openssl11' '--with-openssl=/opt/alt/openssl11' '--with-kerberos' '--with-litespeed' '--enable-pcntl' '--without-mysqli' '--disable-mbstring' '--disable-bcmath' '--disable-dba' '--disable-dom' '--disable-fileinfo' '--disable-json' '--disable-intl' '--disable-pdo' '--disable-phar' '--disable-posix' '--disable-soap' '--disable-sockets' '--disable-sysvsem' '--disable-sysvshm' '--disable-sysvmsg' '--disable-wddx' '--disable-xmlreader' '--disable-xmlwriter' '--disable-zip' '--without-gd' '--without-imap' '--without-xmlrpc' '--without-xsl' '--without-ldap' '--without-pgsql' '--without-snmp' '--without-sodium' '--without-tidy' '--without-enchant' '--without-recode' '--without-mssql' '--without-pspell' '--without-unixODBC' 'build_alias=x86_64-redhat-linux-gnu' 'host_alias=x86_64-redhat-linux-gnu' 'target_alias=x86_64-redhat-linux-gnu' 'CFLAGS=-O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector-strong --param=ssp-buffer-size=4 -grecord-gcc-switches -m64 -mtune=generic -fno-strict-aliasing -Wno-pointer-sign' 'CXXFLAGS=-O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector-strong --param=ssp-buffer-size=4 -grecord-gcc-switches -m64 -mtune=generic'
Server API LiteSpeed V8.0.1 Cloudlinux 1.3
Virtual Directory Support disabled
Configuration File (php.ini) Path /opt/alt/php73/etc
Loaded Configuration File /opt/alt/php73/etc/php.ini
Scan this dir for additional .ini files /opt/alt/php73/link/conf
Additional .ini files parsed /opt/alt/php73/link/conf/alt_php.ini
PHP API 20180731
PHP Extension 20180731
Zend Extension 320180731
Zend Extension Build API320180731,NTS
PHP Extension Build API20180731,NTS
Debug Build no
Thread Safety disabled
Zend Signal Handling enabled
Zend Memory Manager enabled
Zend Multibyte Support provided by mbstring
IPv6 Support enabled
DTrace Support disabled
Registered PHP Streams https, ftps, compress.zlib, compress.bzip2, php, file, glob, data, http, ftp, phar, zip
Registered Stream Socket Transports tcp, udp, unix, udg, ssl, sslv3, tls, tlsv1.0, tlsv1.1, tlsv1.2
Registered Stream Filters zlib.*, bzip2.*, convert.iconv.*, string.rot13, string.toupper, string.tolower, string.strip_tags, convert.*, consumed, dechunk, mcrypt.*, mdecrypt.*
Zend logoThis program makes use of the Zend Scripting Language Engine:
Zend Engine v3.3.33, Copyright (c) 1998-2018 Zend Technologies
with the ionCube PHP Loader + ionCube24 v12.0.5, Copyright (c) 2002-2022, by ionCube Ltd.
Configuration
bcmath
BCMath support enabled
Directive Local Value Master Value
bcmath.scale 0 0
bz2
BZip2 Support Enabled
Stream Wrapper support compress.bzip2://
Stream Filter support bzip2.decompress, bzip2.compress
BZip2 Version 1.0.6, 6-Sept-2010
calendar
Calendar support enabled
Core
PHP Version 7.3.33
allow_url_fopen On On
allow_url_include Off Off
arg_separator.input & &
arg_separator.output & &
auto_append_file no value no value
auto_globals_jit On On
auto_prepend_file no value no value
browscap no value no value
default_charset UTF-8 UTF-8
default_mimetype text/html text/html
disable_classes no value no value
disable_functions no value no value
display_errors Off Off
display_startup_errors Off Off
doc_root no value no value
docref_ext no value no value
docref_root no value no value
enable_dl On On
enable_post_data_reading On On
error_append_string no value no value
error_log no value no value
error_prepend_string no value no value
error_reporting 32767 32767
expose_php On On
extension_dir /opt/alt/php73/usr/lib64/php/modules /opt/alt/php73/usr/lib64/php/modules
file_uploads On On
hard_timeout 2 2
highlight.comment #FF8000 #FF8000
highlight.default #0000BB #0000BB
highlight.html #000000 #000000
highlight.keyword #007700 #007700
highlight.string #DD0000 #DD0000
html_errors On On
ignore_repeated_errors Off Off
ignore_repeated_source Off Off
ignore_user_abort Off Off
implicit_flush Off Off
include_path .:/opt/alt/php73/usr/share/pear .:/opt/alt/php73/usr/share/pear
input_encoding no value no value
internal_encoding no value no value
log_errors On On
log_errors_max_len 1024 1024
mail.add_x_header Off Off
mail.force_extra_parameters no value no value
mail.log /home/jim/.php/php-mail.log no value
max_execution_time 120 120
max_file_uploads 20 20
max_input_nesting_level 64 64
max_input_time -1 -1
max_input_vars 1000 1000
memory_limit 2048M 2048M
open_basedir no value no value
output_buffering 4096 4096
output_encoding no value no value
output_handler no value no value
post_max_size 2048M 2048M
precision 14 14
realpath_cache_size 4096K 4096K
realpath_cache_ttl 120 120
register_argc_argv Off Off
report_memleaks On On
report_zend_debug On On
request_order no value no value
sendmail_from no value no value
sendmail_path /usr/sbin/sendmail -t -i -f [email protected] /usr/sbin/sendmail -t -i
serialize_precision 100 100
short_open_tag On On
SMTP localhost localhost
smtp_port 25 25
sys_temp_dir no value no value
syslog.facility LOG_USER LOG_USER
syslog.filter no-ctrl no-ctrl
syslog.ident php php
track_errors Off Off
unserialize_callback_func no value no value
upload_max_filesize 2048M 2048M
upload_tmp_dir no value no value
user_dir no value no value
user_ini.cache_ttl 300 300
user_ini.filename .user.ini .user.ini
variables_order EGPCS EGPCS
xmlrpc_error_number 0 0
xmlrpc_errors Off Off
zend.assertions 1 1
zend.detect_unicode On On
zend.enable_gc On On
zend.multibyte Off Off
zend.script_encoding no value no value
zend.signal_check Off Off
ctype
ctype functions enabled
curl
cURL support enabled
cURL Information 7.84.0
Age 9
Features
AsynchDNS Yes
CharConv No
Debug No
GSS-Negotiate No
IDN Yes
IPv6 Yes
krb4 No
Largefile Yes
libz Yes
NTLM Yes
NTLMWB Yes
SPNEGO Yes
SSL Yes
SSPI No
TLS-SRP Yes
HTTP2 Yes
GSSAPI Yes
KERBEROS5 Yes
UNIX_SOCKETS Yes
PSL No
HTTPS_PROXY Yes
MULTI_SSL No
BROTLI No
Protocols dict, file, ftp, ftps, gopher, gophers, http, https, imap, imaps, ldap, ldaps, mqtt, pop3, pop3s, rtsp, scp, sftp, smb, smbs, smtp, smtps, telnet, tftp
Host x86_64-redhat-linux-gnu
SSL Version OpenSSL/1.1.1p
ZLib Version 1.2.7
libSSH Version libssh2/1.10.0
curl.cainfo no value no value
date
date/time support enabled
timelib version 2018.04
"Olson" Timezone Database Version 2020.4
Timezone Database internal
Default timezone Europe/Amsterdam
date.default_latitude 31.7667 31.7667
date.default_longitude 35.2333 35.2333
date.sunrise_zenith 90.583333 90.583333
date.sunset_zenith 90.583333 90.583333
date.timezone Europe/Amsterdam Europe/Amsterdam
dom
DOM/XML enabled
DOM/XML API Version 20031129
libxml Version 2.10.2
HTML Support enabled
XPath Support enabled
XPointer Support enabled
Schema Support enabled
RelaxNG Support enabled
exif
EXIF Support enabled
Supported EXIF Version 0220
Supported filetypes JPEG, TIFF
Multibyte decoding support using mbstring enabled
Extended EXIF tag formats Canon, Casio, Fujifilm, Nikon, Olympus, Samsung, Panasonic, DJI, Sony, Pentax, Minolta, Sigma, Foveon, Kyocera, Ricoh, AGFA, Epson
exif.decode_jis_intel JIS JIS
exif.decode_jis_motorola JIS JIS
exif.decode_unicode_intel UCS-2LE UCS-2LE
exif.decode_unicode_motorola UCS-2BE UCS-2BE
exif.encode_jis no value no value
exif.encode_unicode ISO-8859-15 ISO-8859-15
fileinfo
fileinfo support enabled
libmagic 533
filter
Input Validation and Filtering enabled
filter.default unsafe_raw unsafe_raw
filter.default_flags no value no value
ftp
FTP support enabled
FTPS support enabled
gd
GD Support enabled
GD Version bundled (2.1.0 compatible)
FreeType Support enabled
FreeType Linkage with freetype
FreeType Version 2.8.0
GIF Read Support enabled
GIF Create Support enabled
JPEG Support enabled
libJPEG Version 6b
PNG Support enabled
libPNG Version 1.5.13
WBMP Support enabled
XPM Support enabled
libXpm Version 30411
XBM Support enabled
WebP Support enabled
gd.jpeg_ignore_warning 1 1
gettext
GetText Support enabled
gmp
gmp support enabled
GMP version 6.0.0
hash
hash support enabled
Hashing Engines md2 md4 md5 sha1 sha224 sha256 sha384 sha512/224 sha512/256 sha512 sha3-224 sha3-256 sha3-384 sha3-512 ripemd128 ripemd160 ripemd256 ripemd320 whirlpool tiger128,3 tiger160,3 tiger192,3 tiger128,4 tiger160,4 tiger192,4 snefru snefru256 gost gost-crypto adler32 crc32 crc32b fnv132 fnv1a32 fnv164 fnv1a64 joaat haval128,3 haval160,3 haval192,3 haval224,3 haval256,3 haval128,4 haval160,4 haval192,4 haval224,4 haval256,4 haval128,5 haval160,5 haval192,5 haval224,5 haval256,5
MHASH support Enabled
MHASH API Version Emulated Support
iconv
iconv support enabled
iconv implementation glibc
iconv library version 2.17
iconv.input_encoding no value no value
iconv.internal_encoding no value no value
iconv.output_encoding no value no value
imap
IMAP c-Client Version 2007f
SSL Support enabled
Kerberos Support enabled
imap.enable_insecure_rsh Off Off
intl
Internationalization support enabled
ICU version 63.1
ICU Data version 63.1
ICU TZData version 2018e
ICU Unicode version 11.0
intl.default_locale no value no value
intl.error_level 0 0
intl.use_exceptions 0 0
ionCube Loader
ionCube logoionCube24 logo
ionCube Loader developed by ionCube Ltd.
Visit ioncube.com for latest Loaders and support.
This Loader also includes features for real-time error reporting and malware protection. Visit ioncube24.com for more details.
Loader version 12.0.5
ionCube24 features unconfigured
ic24.api.log_msg_errors 0 0
ic24.api.max_timeout 7 7
ic24.api_access_key ******** ********
ic24.api_check_ip 1 1
ic24.enable 0 0
ic24.home_dir no value no value
ic24.phperr.enable auto auto
ic24.phperr.ignore 0 0
ic24.sec.block_stdin 1 1
ic24.sec.block_uploaded_files 1 1
ic24.sec.enable auto auto
ic24.sec.exclusion_key ******** ********
ic24.sec.initial_action block block
ic24.sec.initial_cache_all 1 1
ic24.sec.initial_notify always always
ic24.sec.initial_state 1 1
ic24.sec.stop_on_error 1 1
ic24.sec.trusted_include_paths ******** ********
ic24.slt 7 7
ic24.update_domains_retry_interval 30 30
ioncube.loader.encoded_paths no value no value
json
json support enabled
json version 1.7.0
libxml
libXML support active
libXML Compiled Version 2.10.2
libXML Loaded Version 21002
libXML streams enabled
mbstring
Multibyte Support enabled
Multibyte string engine libmbfl
HTTP input encoding translation disabled
libmbfl version 1.3.2
oniguruma version 6.9.4
mbstring extension makes use of "streamable kanji code filter and converter", which is distributed under the GNU Lesser General Public License version 2.1.
Multibyte (japanese) regex support enabled
Multibyte regex (oniguruma) backtrack check On
Multibyte regex (oniguruma) version 6.9.4
mbstring.detect_order no value no value
mbstring.encoding_translation Off Off
mbstring.func_overload 0 0
mbstring.http_input no value no value
mbstring.http_output no value no value
mbstring.http_output_conv_mimetypes ^(text/|application/xhtml\+xml) ^(text/|application/xhtml\+xml)
mbstring.internal_encoding no value no value
mbstring.language neutral neutral
mbstring.regex_stack_limit 100000 100000
mbstring.strict_detection Off Off
mbstring.substitute_character no value no value
mcrypt
mcrypt support enabled
mcrypt_filter support enabled
Version 2.5.8
Api No 20021217
Supported ciphers cast-128 gost rijndael-128 twofish arcfour cast-256 loki97 rijndael-192 saferplus wake blowfish-compat des rijndael-256 serpent xtea blowfish enigma rc2 tripledes
Supported modes cbc cfb ctr ecb ncfb nofb ofb stream
mcrypt.algorithms_dir no value no value
mcrypt.modes_dir no value no value
mysqli
MysqlI Support enabled
Client API library version mysqlnd 5.0.12-dev - 20150407 - $Id: 7cc7cc96e675f6d72e5cf0f267f48e167c2abb23 $
Active Persistent Links 0
Inactive Persistent Links 0
Active Links 0
mysqli.allow_local_infile Off Off
mysqli.allow_persistent On On
mysqli.default_host no value no value
mysqli.default_port 3306 3306
mysqli.default_pw no value no value
mysqli.default_socket no value no value
mysqli.default_user no value no value
mysqli.max_links Unlimited Unlimited
mysqli.max_persistent Unlimited Unlimited
mysqli.reconnect Off Off
mysqli.rollback_on_cached_plink Off Off
mysqlnd
mysqlnd enabled
Version mysqlnd 5.0.12-dev - 20150407 - $Id: 7cc7cc96e675f6d72e5cf0f267f48e167c2abb23 $
Compression supported
core SSL supported
extended SSL supported
Command buffer size 4096
Read buffer size 32768
Read timeout 86400
Collecting statistics Yes
Collecting memory statistics No
Tracing n/a
Loaded plugins mysqlnd,debug_trace,auth_plugin_mysql_native_password,auth_plugin_mysql_clear_password,auth_plugin_sha256_password
API Extensions mysqli,pdo_mysql
mysqlnd statistics
bytes_sent 0
bytes_received 0
packets_sent 0
packets_received 0
protocol_overhead_in 0
protocol_overhead_out 0
bytes_received_ok_packet 0
bytes_received_eof_packet 0
bytes_received_rset_header_packet 0
bytes_received_rset_field_meta_packet 0
bytes_received_rset_row_packet 0
bytes_received_prepare_response_packet 0
bytes_received_change_user_packet 0
packets_sent_command 0
packets_received_ok 0
packets_received_eof 0
packets_received_rset_header 0
packets_received_rset_field_meta 0
packets_received_rset_row 0
packets_received_prepare_response 0
packets_received_change_user 0
result_set_queries 0
non_result_set_queries 0
no_index_used 0
bad_index_used 0
slow_queries 0
buffered_sets 0
unbuffered_sets 0
ps_buffered_sets 0
ps_unbuffered_sets 0
flushed_normal_sets 0
flushed_ps_sets 0
ps_prepared_never_executed 0
ps_prepared_once_executed 0
rows_fetched_from_server_normal 0
rows_fetched_from_server_ps 0
rows_buffered_from_client_normal 0
rows_buffered_from_client_ps 0
rows_fetched_from_client_normal_buffered 0
rows_fetched_from_client_normal_unbuffered 0
rows_fetched_from_client_ps_buffered 0
rows_fetched_from_client_ps_unbuffered 0
rows_fetched_from_client_ps_cursor 0
rows_affected_normal 0
rows_affected_ps 0
rows_skipped_normal 0
rows_skipped_ps 0
copy_on_write_saved 0
copy_on_write_performed 0
command_buffer_too_small 0
connect_success 0
connect_failure 0
connection_reused 0
reconnect 0
pconnect_success 0
active_connections 0
active_persistent_connections 0
explicit_close 0
implicit_close 0
disconnect_close 0
in_middle_of_command_close 0
explicit_free_result 0
implicit_free_result 0
explicit_stmt_close 0
implicit_stmt_close 0
mem_emalloc_count 0
mem_emalloc_amount 0
mem_ecalloc_count 0
mem_ecalloc_amount 0
mem_erealloc_count 0
mem_erealloc_amount 0
mem_efree_count 0
mem_efree_amount 0
mem_malloc_count 0
mem_malloc_amount 0
mem_calloc_count 0
mem_calloc_amount 0
mem_realloc_count 0
mem_realloc_amount 0
mem_free_count 0
mem_free_amount 0
mem_estrndup_count 0
mem_strndup_count 0
mem_estrdup_count 0
mem_strdup_count 0
mem_edupl_count 0
mem_dupl_count 0
proto_text_fetched_null 0
proto_text_fetched_bit 0
proto_text_fetched_tinyint 0
proto_text_fetched_short 0
proto_text_fetched_int24 0
proto_text_fetched_int 0
proto_text_fetched_bigint 0
proto_text_fetched_decimal 0
proto_text_fetched_float 0
proto_text_fetched_double 0
proto_text_fetched_date 0
proto_text_fetched_year 0
proto_text_fetched_time 0
proto_text_fetched_datetime 0
proto_text_fetched_timestamp 0
proto_text_fetched_string 0
proto_text_fetched_blob 0
proto_text_fetched_enum 0
proto_text_fetched_set 0
proto_text_fetched_geometry 0
proto_text_fetched_other 0
proto_binary_fetched_null 0
proto_binary_fetched_bit 0
proto_binary_fetched_tinyint 0
proto_binary_fetched_short 0
proto_binary_fetched_int24 0
proto_binary_fetched_int 0
proto_binary_fetched_bigint 0
proto_binary_fetched_decimal 0
proto_binary_fetched_float 0
proto_binary_fetched_double 0
proto_binary_fetched_date 0
proto_binary_fetched_year 0
proto_binary_fetched_time 0
proto_binary_fetched_datetime 0
proto_binary_fetched_timestamp 0
proto_binary_fetched_string 0
proto_binary_fetched_json 0
proto_binary_fetched_blob 0
proto_binary_fetched_enum 0
proto_binary_fetched_set 0
proto_binary_fetched_geometry 0
proto_binary_fetched_other 0
init_command_executed_count 0
init_command_failed_count 0
com_quit 0
com_init_db 0
com_query 0
com_field_list 0
com_create_db 0
com_drop_db 0
com_refresh 0
com_shutdown 0
com_statistics 0
com_process_info 0
com_connect 0
com_process_kill 0
com_debug 0
com_ping 0
com_time 0
com_delayed_insert 0
com_change_user 0
com_binlog_dump 0
com_table_dump 0
com_connect_out 0
com_register_slave 0
com_stmt_prepare 0
com_stmt_execute 0
com_stmt_send_long_data 0
com_stmt_close 0
com_stmt_reset 0
com_stmt_set_option 0
com_stmt_fetch 0
com_deamon 0
bytes_received_real_data_normal 0
bytes_received_real_data_ps 0
openssl
OpenSSL support enabled
OpenSSL Library Version OpenSSL 1.1.1p 21 Jun 2022
OpenSSL Header Version OpenSSL 1.1.1p 21 Jun 2022
Openssl default config /opt/alt/openssl11/etc/pki/tls/openssl.cnf
openssl.cafile no value no value
openssl.capath no value no value
pcntl
pcntl support enabled
pcre
PCRE (Perl Compatible Regular Expressions) Support enabled
PCRE Library Version 10.32 2018-09-10
PCRE Unicode Version 11.0.0
PCRE JIT Support enabled
PCRE JIT Target x86 64bit (little endian + unaligned)
pcre.backtrack_limit 1000000 1000000
pcre.jit 1 1
pcre.recursion_limit 100000 100000
PDO
PDO support enabled
PDO drivers mysql, sqlite
pdo_mysql
PDO Driver for MySQL enabled
Client API version mysqlnd 5.0.12-dev - 20150407 - $Id: 7cc7cc96e675f6d72e5cf0f267f48e167c2abb23 $
pdo_mysql.default_socket /tmp/mysql.sock /tmp/mysql.sock
pdo_sqlite
PDO Driver for SQLite 3.x enabled
SQLite Library 3.39.4
Phar
Phar: PHP Archive support enabled
Phar API version 1.1.1
Phar-based phar archives enabled
Tar-based phar archives enabled
ZIP-based phar archives enabled
gzip compression enabled
bzip2 compression enabled
Phar based on pear/PHP_Archive, original concept by Davey Shafik.
Phar fully realized by Gregory Beaver and Marcus Boerger.
Portions of tar implementation Copyright (c) 2003-2009 Tim Kientzle.
phar.cache_list no value no value
phar.readonly On On
phar.require_hash On On
posix
POSIX support enabled
readline
Readline Support enabled
Readline library 6.2
cli.pager no value no value
cli.prompt \b \> \b \>
Reflection
Reflection enabled
session
Session Support enabled
Registered save handlers files user
Registered serializer handlers php_serialize php php_binary
session.auto_start Off Off
session.cache_expire 180 180
session.cache_limiter nocache nocache
session.cookie_domain no value no value
session.cookie_httponly no value no value
session.cookie_lifetime 0 0
session.cookie_path / /
session.cookie_samesite no value no value
session.cookie_secure 0 0
session.gc_divisor 1000 1000
session.gc_maxlifetime 1440 1440
session.gc_probability 1 1
session.lazy_write On On
session.name PHPSESSID PHPSESSID
session.referer_check no value no value
session.save_handler files files
session.save_path /opt/alt/php73/var/lib/php/session /opt/alt/php73/var/lib/php/session
session.serialize_handler php php
session.sid_bits_per_character 4 4
session.sid_length 32 32
session.upload_progress.cleanup On On
session.upload_progress.enabled On On
session.upload_progress.freq 1% 1%
session.upload_progress.min_freq 1 1
session.upload_progress.name PHP_SESSION_UPLOAD_PROGRESS PHP_SESSION_UPLOAD_PROGRESS
session.upload_progress.prefix upload_progress_ upload_progress_
session.use_cookies 1 1
session.use_only_cookies 1 1
session.use_strict_mode 0 0
session.use_trans_sid 0 0
shmop
shmop support enabled
SimpleXML
SimpleXML support enabled
Schema support enabled
soap
Soap Client enabled
Soap Server enabled
soap.wsdl_cache 1 1
soap.wsdl_cache_dir /tmp /tmp
soap.wsdl_cache_enabled 1 1
soap.wsdl_cache_limit 5 5
soap.wsdl_cache_ttl 86400 86400
sockets
Sockets Support enabled
SPL
SPL support enabled
Interfaces OuterIterator, RecursiveIterator, SeekableIterator, SplObserver, SplSubject
Classes AppendIterator, ArrayIterator, ArrayObject, BadFunctionCallException, BadMethodCallException, CachingIterator, CallbackFilterIterator, DirectoryIterator, DomainException, EmptyIterator, FilesystemIterator, FilterIterator, GlobIterator, InfiniteIterator, InvalidArgumentException, IteratorIterator, LengthException, LimitIterator, LogicException, MultipleIterator, NoRewindIterator, OutOfBoundsException, OutOfRangeException, OverflowException, ParentIterator, RangeException, RecursiveArrayIterator, RecursiveCachingIterator, RecursiveCallbackFilterIterator, RecursiveDirectoryIterator, RecursiveFilterIterator, RecursiveIteratorIterator, RecursiveRegexIterator, RecursiveTreeIterator, RegexIterator, RuntimeException, SplDoublyLinkedList, SplFileInfo, SplFileObject, SplFixedArray, SplHeap, SplMinHeap, SplMaxHeap, SplObjectStorage, SplPriorityQueue, SplQueue, SplStack, SplTempFileObject, UnderflowException, UnexpectedValueException
sqlite3
SQLite3 support enabled
SQLite Library 3.28.0
sqlite3.defensive 1 1
sqlite3.extension_dir no value no value
standard
Dynamic Library Support enabled
Path to sendmail /usr/sbin/sendmail -t -i -f [email protected]
assert.active 1 1
assert.bail 0 0
assert.callback no value no value
assert.exception 0 0
assert.quiet_eval 0 0
assert.warning 1 1
auto_detect_line_endings 0 0
default_socket_timeout 60 60
session.trans_sid_hosts no value no value
session.trans_sid_tags a=href,area=href,frame=src,form= a=href,area=href,frame=src,form=
url_rewriter.hosts no value no value
url_rewriter.tags a=href,area=href,frame=src,input=src,form=fakeentry a=href,area=href,frame=src,input=src,form=fakeentry
user_agent no value no value
tokenizer
Tokenizer Support enabled
xml
XML Support active
XML Namespace Support active
libxml2 Version 2.10.2
xmlreader
XMLReader enabled
xmlwriter
XMLWriter enabled
xsl
XSL enabled
libxslt Version 1.1.28
libxslt compiled against libxml Version 2.9.1
EXSLT enabled
libexslt Version 1.1.28
zip
Zip enabled
Zip version 1.15.4
Libzip headers version 1.3.2
Libzip library version 1.3.2
zlib
ZLib Support enabled
Stream Wrapper compress.zlib://
Stream Filter zlib.inflate, zlib.deflate
Compiled Version 1.2.7
Linked Version 1.2.7
zlib.output_compression Off Off
zlib.output_compression_level -1 -1
zlib.output_handler no value no value
Additional Modules
Module Name
litespeed
Environment
Variable Value
PATH /usr/local/bin:/usr/bin:/bin
TEMP /tmp
TMP /tmp
TMPDIR /tmp
PWD /
PHP Variables
Variable Value
$_REQUEST['cookieconsent_status'] dismiss
$_REQUEST['XSRF-TOKEN'] eyJpdiI6IlpodmV2cGIwWGd6YS9Gb2ZNcGFWOVE9PSIsInZhbHVlIjoiNHlCU3JwTWJQUEVRRWRBMThPWCtLQ1lTdjJHaXVVeWIvTTl0ODFNdS9aUTdxakh1VCs4eG5tekFtZEd0d3R5QVNhUHB6S0h0NzZjWFhyYTV0R2crNHRTSkdyOExXdkgweG9aMHRRN2hvK0pzYkxiS3IzVTdTenlxcGE0ZmxjbnQiLCJtYWMiOiJiNmFjMGQ3MjQ4OGVjZGVkMGMzMzczNzEzYjM1OWM1ZTQ2ZDRjYmE0ODZmODI1N2U1MzE2Nzk2ZmM3YjliYmQ1IiwidGFnIjoiIn0=
$_REQUEST['invoice_ninja_session'] eyJpdiI6ImhCc1lXZDNOK3lkOTNRUlJVeWI1Tmc9PSIsInZhbHVlIjoiaVBKd0dmQnIwaXNBeWNEckU0RXNSZ0I2U3dpMDZ2OWIxUUhKMmsxbXJMQkU2SGQ4VmZIRXg0S3BKNkphQ0cvVDRETDYvKzk4OXM5cGhvNEUxbDRDM3FLR2pRVHk0QWVNSGR1Mzk5QmFKL2twcVRtR0ZseU1kZEJ3ZjJmRnFJNDYiLCJtYWMiOiJlMTAxMGVlMmFmMGEwY2Q0MGY2NzRjNDYyOTRlMDRkNDM3ODVmYmJjZmYzNzZlOTliOGQxMDZjODYzMjBkZTZjIiwidGFnIjoiIn0=
$_REQUEST['roundcube_sessid'] vv3lgs1dmp1e19n6s8i4fh8gt6
$_REQUEST['roundcube_sessauth'] 8rSyEOQD9w0D2K2uFyJIiI0XDF-1681584300
$_COOKIE['cookieconsent_status'] dismiss
$_COOKIE['XSRF-TOKEN'] eyJpdiI6IlpodmV2cGIwWGd6YS9Gb2ZNcGFWOVE9PSIsInZhbHVlIjoiNHlCU3JwTWJQUEVRRWRBMThPWCtLQ1lTdjJHaXVVeWIvTTl0ODFNdS9aUTdxakh1VCs4eG5tekFtZEd0d3R5QVNhUHB6S0h0NzZjWFhyYTV0R2crNHRTSkdyOExXdkgweG9aMHRRN2hvK0pzYkxiS3IzVTdTenlxcGE0ZmxjbnQiLCJtYWMiOiJiNmFjMGQ3MjQ4OGVjZGVkMGMzMzczNzEzYjM1OWM1ZTQ2ZDRjYmE0ODZmODI1N2U1MzE2Nzk2ZmM3YjliYmQ1IiwidGFnIjoiIn0=
$_COOKIE['invoice_ninja_session'] eyJpdiI6ImhCc1lXZDNOK3lkOTNRUlJVeWI1Tmc9PSIsInZhbHVlIjoiaVBKd0dmQnIwaXNBeWNEckU0RXNSZ0I2U3dpMDZ2OWIxUUhKMmsxbXJMQkU2SGQ4VmZIRXg0S3BKNkphQ0cvVDRETDYvKzk4OXM5cGhvNEUxbDRDM3FLR2pRVHk0QWVNSGR1Mzk5QmFKL2twcVRtR0ZseU1kZEJ3ZjJmRnFJNDYiLCJtYWMiOiJlMTAxMGVlMmFmMGEwY2Q0MGY2NzRjNDYyOTRlMDRkNDM3ODVmYmJjZmYzNzZlOTliOGQxMDZjODYzMjBkZTZjIiwidGFnIjoiIn0=
$_COOKIE['roundcube_sessid'] vv3lgs1dmp1e19n6s8i4fh8gt6
$_COOKIE['roundcube_sessauth'] 8rSyEOQD9w0D2K2uFyJIiI0XDF-1681584300
$_SERVER['PATH'] /usr/local/bin:/usr/bin:/bin
$_SERVER['TEMP'] /tmp
$_SERVER['TMP'] /tmp
$_SERVER['TMPDIR'] /tmp
$_SERVER['PWD'] /
$_SERVER['HTTP_ACCEPT'] text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,image/apng,*/*;q=0.8,application/signed-exchange;v=b3;q=0.7
$_SERVER['HTTP_ACCEPT_ENCODING'] gzip, deflate
$_SERVER['HTTP_ACCEPT_LANGUAGE'] en-GB,en;q=0.9,nl-NL;q=0.8,nl;q=0.7,en-US;q=0.6
$_SERVER['HTTP_CONNECTION'] close
$_SERVER['CONTENT_LENGTH'] 0
$_SERVER['HTTP_COOKIE'] cookieconsent_status=dismiss; XSRF-TOKEN=eyJpdiI6IlpodmV2cGIwWGd6YS9Gb2ZNcGFWOVE9PSIsInZhbHVlIjoiNHlCU3JwTWJQUEVRRWRBMThPWCtLQ1lTdjJHaXVVeWIvTTl0ODFNdS9aUTdxakh1VCs4eG5tekFtZEd0d3R5QVNhUHB6S0h0NzZjWFhyYTV0R2crNHRTSkdyOExXdkgweG9aMHRRN2hvK0pzYkxiS3IzVTdTenlxcGE0ZmxjbnQiLCJtYWMiOiJiNmFjMGQ3MjQ4OGVjZGVkMGMzMzczNzEzYjM1OWM1ZTQ2ZDRjYmE0ODZmODI1N2U1MzE2Nzk2ZmM3YjliYmQ1IiwidGFnIjoiIn0%3D; invoice_ninja_session=eyJpdiI6ImhCc1lXZDNOK3lkOTNRUlJVeWI1Tmc9PSIsInZhbHVlIjoiaVBKd0dmQnIwaXNBeWNEckU0RXNSZ0I2U3dpMDZ2OWIxUUhKMmsxbXJMQkU2SGQ4VmZIRXg0S3BKNkphQ0cvVDRETDYvKzk4OXM5cGhvNEUxbDRDM3FLR2pRVHk0QWVNSGR1Mzk5QmFKL2twcVRtR0ZseU1kZEJ3ZjJmRnFJNDYiLCJtYWMiOiJlMTAxMGVlMmFmMGEwY2Q0MGY2NzRjNDYyOTRlMDRkNDM3ODVmYmJjZmYzNzZlOTliOGQxMDZjODYzMjBkZTZjIiwidGFnIjoiIn0%3D; roundcube_sessid=vv3lgs1dmp1e19n6s8i4fh8gt6; roundcube_sessauth=8rSyEOQD9w0D2K2uFyJIiI0XDF-1681584300
$_SERVER['HTTP_HOST'] slimjim.eu
$_SERVER['HTTP_USER_AGENT'] Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/111.0.0.0 Safari/537.36
$_SERVER['HTTP_CACHE_CONTROL'] max-age=0
$_SERVER['HTTP_UPGRADE_INSECURE_REQUESTS'] 1
$_SERVER['HTTP_X_ZXCS_URI'] /phpinfo.php
$_SERVER['HTTP_X_ZXCS_VHOST'] slimjim.eu
$_SERVER['HTTP_X_FORWARDED_PORT'] 80
$_SERVER['HTTP_REMOTE_ADDR'] 2a06:2ec0:1::101
$_SERVER['UNIQUE_ID'] ZDryNHJ6QDvuVttJPulbJQAAAIM
$_SERVER['SERVER_SIGNATURE'] no value
$_SERVER['SERVER_SOFTWARE'] Apache/2
$_SERVER['SERVER_NAME'] slimjim.eu
$_SERVER['SERVER_ADDR'] 127.0.0.1
$_SERVER['SERVER_PORT'] 80
$_SERVER['REMOTE_ADDR'] 2a02:a464:e562:1:bcc9:b209:8825:fbff
$_SERVER['DOCUMENT_ROOT'] /home/jim/domains/slimjim.eu/public_html
$_SERVER['REQUEST_SCHEME'] http
$_SERVER['CONTEXT_PREFIX'] no value
$_SERVER['CONTEXT_DOCUMENT_ROOT'] /home/jim/domains/slimjim.eu/public_html
$_SERVER['SERVER_ADMIN'] [email protected]
$_SERVER['SCRIPT_FILENAME'] /home/jim/domains/slimjim.eu/public_html/phpinfo.php
$_SERVER['REMOTE_PORT'] 52838
$_SERVER['SERVER_PROTOCOL'] HTTP/1.1
$_SERVER['REQUEST_METHOD'] GET
$_SERVER['QUERY_STRING'] no value
$_SERVER['REQUEST_URI'] /phpinfo.php
$_SERVER['SCRIPT_NAME'] /phpinfo.php
$_SERVER['PHP_SELF'] /phpinfo.php
$_SERVER['REQUEST_TIME_FLOAT'] 1681584692.7263
$_SERVER['REQUEST_TIME'] 1681584692
$_ENV['PATH'] /usr/local/bin:/usr/bin:/bin
$_ENV['TEMP'] /tmp
$_ENV['TMP'] /tmp
$_ENV['TMPDIR'] /tmp
$_ENV['PWD'] /
