Need Help Combining Quantity and Units into One Field - Is There a Function for This?
Hello everyone,
I have a problem with the units.
I use Quantity for the amount and Custom field with the name unit for, for example, kg or m³…
Is it possible for me to have both in one field so it doesn’t look so weird?
Or is there a function to enter units?
This isn’t currently supported but it should be possible when we release support for TWIG templating later this year.
Is there a solution for that by now?
I believe this should be possible using a template
But beware! Using templates or twig-code within invoices, quotes etc. involves limitations if you optionally include task-details within service-descriptions! Twig cannot interprete html-code within variable-values. I just mention this, because it took me several sleepless nights until I recognized this. :frowning:
