Hi, I’m stuck. Using the latest V4, I just did a fresh install for the first time and I can’t get emails to work.
I have a separate email server with Mailcheap (just a basic shared account) as I did not want to manage any email daemons / accounts / files on my web servers.
The account with Mailcheap is not necessarily an SMTP service… again, I did not want to learn to become an email protocol expert, so I don’t know the details of their implimenation.
By default I could not get emails to send from WordPress either, but somehow the plugin WP Mail SMTP fixes that problem and my emails get sent. All I have to do is input the same information that I’ve input into the InvoiceNinja settings – literally all of the exact same fields under Email Settings.
So I’m wondering, what is the magic trick that WP Mail SMTP is employing? Do any experts know? And how could I apply it to my instance of InvoiceNinja?
When I run the “Send test email” button with SMTP selected, I get a timeout:
Connection could not be established with host mail14.mymailcheap.com [Connection timed out #110]
- Yes port 587 is open in my firewall.
- The host is in fact mail14.mymailcheap.com
- I’m using TLS, works fine with my WordPress sites
When I change the Driver to “Mail” I get a more immediate failure:
Expected response code 220 but got an empty response
If it helps, here are the DNS records I use for my WordPress sites (and this instance):
MX mail14.mymailcheap.com TTL 1800 Priority 1
MX alt1.mymailcheap.com TTL 1800 Priority 5
MX alt2.mymailcheap.com TTL 1800 Priority 10
NS ns1.vultr.com TTL 300
NS ns2.vultr.com TTL 300
TXT "v=spf1 mx a:relay.mymailcheap.com -all" TTL 1800
TXT _dmarc "v=DMARC1; p=none" TTL 1800
I don’t recall having to make any changes to my Mailcheap settings to get my WordPress sites to send emails. It must come down to something in the PHP, which that WP plugin seems to fix. Any ideas?
It’s not ModSecurity either, I’ve disabled it and I get the same error.
