I can see this topic has been discussed, but it is not working for me.
I have tried to add under taxes 2 lines. one to add 10% GST tax and a second as 10% GST included.
Basically depending on the supplier on some items I need to put $100 then select add 10% tax and that works correctly as designed ie shows $110 as total cost.
For other items in which the vendor has already included tax, I want to be able to put $110 and have displayed ‘10% GST tax included’. but in this case I don’t want 10% being added to the total.
So the ability to have tax as inclusive does not appear to work unless I am doing something wrong. The work around is for me to sit there and subtract tax off every item from the vendor. any help appreciated. regards
There’s an ‘Inclusive Taxes’ option in the settings however it would apply to all taxes on the invoice, the app doesn’t support adding an inclusive and exclusive tax to the one invoice.
