Hello Everybody
i did a quick search inside the forum about how to install Invoice Ninja onto synology NAS and i didn’t find posts.
somebody has tried ? with success ? hope yes and it will be cool if one of you can guide me how to do it.
thanks in advance.
I have successfully installed invoice ninja on my synology. I used the docker image. My synology model is a DS713+
Hello, could you explain what configuration do you use?
Ports? Network?
I have same problems.
Yes same for me, I have tried with the docker container here : https://github.com/invoiceninja/dockerfiles
I’ve added the variables in the Environement but “Docker container: invoiceninja stopped unexpectedly.” each time I try to run it.
Please give us a tutorial.
Thanks.
Can you help me with Synology install? do you have docker commands for synology
