Hi
I’m having issues installing Invoice Ninja in Shared Hosting via Namecheap. I’m receiving errors about
Invoice Ninja Version : v5.3.0-c58
Hoping for any response about the issue
Hi
Have the crons been configured?
The cron should be set to run every minute.
@david does refreshing data now check if the cron has been enabled?
Have you seen this info regarding emails:
https://invoiceninja.github.io/docs/self-host-troubleshooting/#email-not-sending
I’ve tried changing it now to every minute. As of writing this reply still seeing the error.
Yes on 5.3.x running /update?secret= will also test the crons are working.
Will try to check if the update prefix are working to check if cron is working
I’ve tried it and 404 | Not Found
You’re loading /upgrade rather than /update
Note: you may want to change your secret
Are you seeing a 404 loading /update or using the app?
When loading the upgrade yes I see 404
Are you loading /upgrade (not correct) or /update (correct)
I mean update. Yes I still see 404 error
Also I can’t update the version from the Update Available. If trying to update to the new version it keeps replying “Server Error”
I think the issue is solved by the update v5.3.1-C58… Will update this thread again if I still encountered the issue. Thank you!
