I have been trying like hell to get IN installed via docker using docker compose. I’ve followed the docs, followed two different videos and tried things I’ve found searching the issues.
I have tried installing this in a DigitalOcean VPS as well as my owner homelab server. No go with either.
My problem appears to be connecting to MySQL. Connection fails and the container restarts. Over and over and over. This is the output of the MySQL container logs:
2024-01-31 18:04:35+00:00 [Note] [Entrypoint]: Entrypoint script for MySQL Server 8.3.0-1.el8 started.
2024-01-31 18:04:37+00:00 [Note] [Entrypoint]: Switching to dedicated user 'mysql'
2024-01-31 18:04:37+00:00 [Note] [Entrypoint]: Entrypoint script for MySQL Server 8.3.0-1.el8 started.
'/var/lib/mysql/mysql.sock' -> '/var/run/mysqld/mysqld.sock'
That just repeats over and over every few seconds. This is error in the app log:
In Connection.php line 822:
SQLSTATE[HY000] [2002] php_network_getaddresses: getaddrinfo for db failed:
Try again (Connection: mysql, SQL: select table_name as `name`, (data_leng
th + index_length) as `size`, table_comment as `comment`, engine as `engine
`, table_collation as `collation` from information_schema.tables where tabl
e_schema = 'ninja' and table_type in ('BASE TABLE', 'SYSTEM VERSIONED') ord
er by table_name)
In Connector.php line 65:
Try again
PDO::__construct(): php_network_getaddresses: getaddrinfo for db failed: Tr
y again
Here is my env file:
# IN application vars
APP_URL=http://myip:8555
APP_KEY=somethingsomethingsecret
APP_DEBUG=true
REQUIRE_HTTPS=false
PDF_GENERATOR=snappdf
TRUSTED_PROXIES='*'
QUEUE_CONNECTION=database
# DB connection
DB_HOST=db
DB_PORT=3306
DB_DATABASE=ninja
DB_USERNAME=ninja
DB_PASSWORD=ninja
# Create initial user
# [email protected]
# IN_PASSWORD=changeme!
[email protected]
IN_PASSWORD=thepassword
# Mail options
MAIL_MAILER=log
MAIL_HOST=my.smtp.relay.example.com
MAIL_PORT=587
[email protected]
MAIL_PASSWORD=secretstuff
MAIL_ENCRYPTION=tls
MAIL_FROM_ADDRESS='[email protected]'
MAIL_FROM_NAME='Self Hosted User'
# MySQL
MYSQL_ROOT_PASSWORD=ninjaAdm1nPassword
MYSQL_USER=ninja
MYSQL_PASSWORD=ninja
MYSQL_DATABASE=ninja
# V4 env vars
# DB_STRICT=false
# APP_CIPHER=AES-256-CBC
I left this as generic as possible after trying multiple times with personalized settings but still no go. Here’s my docker compose:
version: '3.7'
services:
server:
image: nginx
restart: always
env_file: env
volumes:
# Vhost configuration
#- ./config/caddy/Caddyfile:/etc/caddy/Caddyfiledocker-com
- ./docker/app/public:/var/www/app/public:ro
depends_on:
- app
# Run webserver nginx on port 80
# Feel free to modify depending what port is already occupied
ports:
- "8555:80"
#- "443:443"
networks:
- invoiceninja
app:
env_file: env
restart: always
volumes:
- ./config/php/php.ini:/usr/local/etc/php/php.ini
- ./config/php/php-cli.ini:/usr/local/etc/php/php-cli.ini
depends_on:
- db
networks:
- invoiceninja
db:
image: mysql:8
ports:
- "3305:3306"
restart: always
env_file: env
volumes:
- ./docker/mysql/data:/var/lib/mysql:rw,delegated
networks:
- invoiceninja
networks:
invoiceninja:
I can provide further information if needed but please be wordy in what you are requesting as I am pretty new to docker. Thank you.
