I am checking our invoice ninja. We need some additional custom fields for products and for customers.
e.g. for products I might need a “category” of the product and a “unit type” like hours, kg, years…
At a first glance it looks like as if it is only possible to add 4 custom fields? Is it possible to add more than 4 custom fields?
Thanks a lot
Cornelius
January 1, 2022, 6:06pm
Sorry, it isn’t supported
Are there any plans to add support for more custom fields in the future?
March 23, 2022, 4:38pm
4
We don’t have immediate plans to support more
Hi @hillel ,
I’m also looking for something like that and I was thinking, can I change the name of one field already in the products section?
Like, the description, I’m not using it, can I replace the name and start too use it?
Thanks…
But, how can I do it?
In the code? or there’s a CSS code I could use it?
Because if I change in the code, when I update it, it will be back.
October 17, 2023, 4:06pm
8
You can set a custom label on Settings > Localization > Custom Labels
