sometimes invoice status doesn’t change even if the payment is done correctly by mollie, that can be due to the old version of mollie (V1) used by invoice Ninja, i would like to migrate mollie from V1 to V2 in invoice Ninja if someone can guide me please
Hi Hillel,
i think 4.5.19
The latest v5 version of the app uses the new v2 Mollie API.
thank you for your answer, the probleme is we made many change to customize the app according to our needs. if there is an other solution to change only the mollie version ?
Sorry, that’s the only solution I’m aware of
