New to forums but I’m here trying to figure out a resolution to this issue.
I am able to install v4 and v5 on my shared hosted box running cPanel. The apps run fine (both versions) but I’m trying to get the tickets module installed and when i run the following command for either version I run into an error:
RESULT:
Cloning into ‘/home/cloudwis/service.cloudwise.ca/Modules/Tickets’…
ssh: connect to host github.com port 65001: Connection timed out
fatal: Could not read from remote repository.
Please make sure you have the correct access rights
and the repository exists.
Running for module: Tickets
In FileRepository.php line 396:
Module [Tickets] does not exist!
Anyone have any idea why it’s doing this? I can’t nmap to test port, but is there a way I could install this without the artisan command? Maybe manually upload the folder with the module files?
Sorry one last question… How do I install the develop branch? After uploading files, going to mydomain.com/setup i get a 404 error and I don’t see any further instructions on install of develop branch. What am I doing wrong?
2021-03-23 14:41:42.521813 [INFO] [385901] [143.131.6.101:30899-2#APVH_service.mydomain.ca:443] File not found [/home/mydomain/service.mydomain.ca/404.shtml]
2021-03-23 14:41:42.521768 [INFO] [385901] [143.131.6.101:30899-2#APVH_service.mydomain.ca:443] File not found [/home/mydomain/service.mydomain.ca/flutter_service_worker.js]
It’s thinking the file is missing. I’ve tried with and without the rewrite rule in .htaccess. With it on, I get an error 500.
Guess I might as well just give up lol -_- Was worth the attempt i guess
