How is it possible to modify template?
I would like to add property address field in rounded section (see screenshot attached)
Please advise.
Please advise.
You can configure which fields are shown in that section on Settings > Invoice Design > Client Details.
Maybe you can use a custom contact field?
Thank you!
it works but only for new clients created.
for the client objects already created it does not work and I do not see ability to update it.
I’ve tried to include shipping address (it is what I need to display) but there is no such option in drop down to select???
also, opened client object and where can I look for the contact custom 1 field ?
please advise!
The custom contact value isn’t shown on the client view page but I do see it in the edit client form.
