I have client where it shows paid to date 2560
But it shows 7 invoices with amounts 500, 500, 300, 300, 100, 300, 60. (2060)
Where is the 500 missing?
There is no Archived or deleted invoices for this client.
What do you see if you run php artisan ninja:check-data
Also, are you using the web app or the desktop app?
2024-09-24 07:31:46 2024-09-24 07:31:46 Running CheckData… on Connected to Default DB Fix Status = Just checking issues
2024-09-24 07:31:46 0 clients with incorrect balances
2024-09-24 07:31:46 Client 1 id = # 13 - Client Paid To Date = 1690.240000 != Invoice Payments = 1695.15 - 1695.150000 +
2024-09-24 07:31:46 The client id = # 31 - Client Paid To Date = 2845.000000 != Invoice Payments = 3795 - 3795.000000 +
2024-09-24 07:31:46 2 clients with incorrect paid to dates
2024-09-24 07:31:46 0 contacts without a contact_key
2024-09-24 07:31:46 0 clients without any contacts
2024-09-24 07:31:46 0 vendors without any contacts
2024-09-24 07:31:46 0 wrong invoices with bad balance state
2024-09-24 07:31:46 0 Contacts with Send Email = true but no email address
2024-09-24 07:31:46 126 Payments with No currency set
2024-09-24 07:31:46 Fixing - exchange rate for expense :: 21
2024-09-24 07:31:46 Fixing - exchange rate for expense :: 66
2024-09-24 07:31:46 Fixing - exchange rate for expense :: 176
2024-09-24 07:31:46 0 users with duplicate oauth ids
2024-09-24 07:31:46 Done: FAILURE
2024-09-24 07:31:46 Total execution time in seconds: 0.075825929641724
I am using desktop app.
Also for some reason it was showing amount in Dashboard last 30days less than this month. But it shows ok now.
You can add --fix to fix these issues but it doesn’t look like it includes the 500 client.
If you have a large account you may need to increase the number of years to load on Settings > User Details. You may also want to check in the web app.
I checked the web app switched to react:
And it shows the missing 500eur!
It was the first invoice for this client in 2021.
Also it shows balance like this:
Standing
Paid to Date
€ 2,560.00
Outstanding
€ 0.00
Credit Balance
€ 0.00
Payment Balance
€ 60.00
Not sure why Payment Balance is 60
That was set to 3. I set it to 5 and it resolved the issue.
thanks!
php artisan ninja:check-data --fix
It does not fix the data. Still same result.
Try this instead
php artisan ninja:check-data --fix=true --client_balance=true
