Hi
I am using IN4 and IN5 on the same docker with different ports (v4: 88, v5: 89)
When starting the migration in IN4 everything looks good. The UI tells me, that the migration is started and I will get an email when it’s finished. But this email is never coming.
Also there is no zip-file in the migrations-folder.
I used portioner to setup the apps. IN4 and IN5 running three container (server, app, db) and I can use each app individually without any issues.
Unfortunately I have no logs in the logs-folder.
Regards
Martin
