I can’t seem to get the migration to work. Here’s the background for my self-hosted install and what I’ve done:
I was running V4 (on Debian 9) for approx 2 years and used the update script (which was the same script I have been using and is approx 6 mos old.) I didn’t ensure PHP7.2 was installed. I was running 7.0. I installed the 7.2 and got my v4 up and running again (4.5.43). All v4 functions seem fine now. I mention this because maybe it’s involved in the issue and I have a PHP problem. (nginx .conf file was changed to php7.2 and “php7.2 artisan optimize” was run.)
I’ve got v5 (v5.3.8-C58) up and running on Ubuntu 20.04. I pointed my existing revproxy server config to the new internal IP address of the v5 instance. No problems there - the v5 site loads fine from the web with https and no certificate warnings are shown. This means my V4 instance is no longer web-accessible - not sure if this is an issue for the upgrade - works fine on LAN though. Using the internal LAN address to the V4 server on http (not https), I clicked the migration button and pointed to the external FQDN https:// address of my V5 server. User name and password/secret don’t seem to be an issue. It says it will email when the migration is finished. Doesn’t seem to do anything after a couple of minutes (maybe just seconds) and I did leave it run for several hours at one point - nothing new in logs and .zip described below doesn’t increase in size.
It just seems to stop. Every time I run it, it creates a new zip in /var/www/html/ninja/storage/app/migrations
and doesn’t seem to grow to a reasonable size. It always stops with only about 599KB of data. Nothing shows up in the laravel-errror.log, nothing in the nginx log. The larvel-info.log stops every time at “production.INFO: get documents [ ] [ ]” (see below).
Nothing shows up in the V5 system logs at all.
V5 and V4 files are all www-data owned.
I’m reasonably sure I have the crontab set up properly on V5 but maybe worth confirming (path is confirmed):
'# m h dom mon dow command
- php7.4 /usr/share/nginx/invoiceninja/artisan schedule:run >> /dev/null 2>&1
I didn’t setup email or any other functions in V5. Basically vanilla but I created a user/pw that match the V4 setup.
Here’s the log mentioned (laravel-info.log) and where it starts and stops when migration button is triggered:
[2021-09-08 21:54:26] production.INFO: get account [] []
[2021-09-08 21:54:26] production.INFO: get company [] []
[2021-09-08 21:54:26] production.INFO: get co settings [] []
[2021-09-08 21:54:26] production.INFO: get users [] []
[2021-09-08 21:54:26] production.INFO: get tax rates [] []
[2021-09-08 21:54:26] production.INFO: get payment terms [] []
[2021-09-08 21:54:26] production.INFO: get clients [] []
[2021-09-08 21:54:26] production.INFO: get get company gateways [] []
[2021-09-08 21:54:26] production.INFO: get client gateway tokens [] []
[2021-09-08 21:54:26] production.INFO: get vendors [] []
[2021-09-08 21:54:26] production.INFO: get projects [] []
[2021-09-08 21:54:26] production.INFO: get products [] []
[2021-09-08 21:54:26] production.INFO: get credit notes [] []
[2021-09-08 21:54:26] production.INFO: get invoices [] []
[2021-09-08 21:54:29] production.INFO: get recurring invoices [] []
[2021-09-08 21:54:29] production.INFO: get quotes [] []
[2021-09-08 21:54:29] production.INFO: get payments [] []
[2021-09-08 21:54:30] production.INFO: get credits [] []
[2021-09-08 21:54:30] production.INFO: get documents [] []
[2021-09-08 21:54:30] production.INFO: get expense categories [] []
[2021-09-08 21:54:30] production.INFO: get task statuses [] []
[2021-09-08 21:54:30] production.INFO: get expenses [] []
[2021-09-08 21:54:30] production.INFO: get tasks [] []
[2021-09-08 21:54:31] production.INFO: get documents [] []
Any help would be appreciated. I’m not sure what to look at from here.
Thanks and regards,
Shawn.
