Hi
I’m running a migration of a clients old Invoice Ninja v4.5.50 install to a new version V5.8.46
The migration runs successfully and says it will notify once the migration is complete but when I check the new version it looks like only 1/4 of the data (Invoices and payments) has been migrated across.
Is there a time limit cut off for migrations or something that is preventing the migration of all the data to be migrated across?
I have updated the php settings for files sizes and so on
Hi
Still the same issue, I only see 1/4 of the invoices and payments migrated across.
No error messages in the logs.
I only have 1gig memory and both installs are on the same server not sure if it will need more resources, I have increased all the PHP resources.
There was a strange glitch that happen, when I cleared cache and login in again it did show all the records for invoices but then after refreshing it reverted back to the previous amount.
How does the migration work does it create a zip of the data first or is the data migrated straight across? the mysql db is over 100mb.
