Migrating V4 to V5
Dear All and thanks for your help in advnace. I’m trying to finally migrate from V4 to V5. I am trying to install V5 but running into the issue that PHP needs to be 8.1 but V4 doesnt work with this higher version. So I’ve gone to CPanel to look for MultiPHP switcher but my host does not support MultiPHP switcher. Is there another way to resolve this problem or do I really need to find another host that supports MultiPHP switcher?
Many Thanks J
Sorry, I’m not aware of another solution.
Thanks my host is trying to set the PHP manually for me to allow it to happen. Thanks
Alternatively could I migrate all my settings and data over to a paid plan hosted via Invoice Ninja, then install V5 with my host then migrate the settings and data back to my self hosted V5?
The migration only works to transfer data from v4 to v5.
If you migrate to v5 hosted you could export your data as JSON but the results won’t be as good.
