I wanted to find out firstly if it is feasible to migrate from Invoice Ninja Hosted (4.x) to Self Hosted(5.x)?
Secondly would I just export out of Hosted via Json and then import directly into 5.x?
To use the JSON file you’d need to first setup a v4 selfhost instance and then use the migration tool to migrate to v5.
Another option would be to export the data as CSV and import that directly into v5.
