Migrate to the debian-image (help)
Loving this software.
I want to migrate to the debian-image docker
Couldn’t find the migration guide to the debian-image
services:
  server:
    image: nginx
    restart: always
    env_file: env
    volumes:
      # Vhost configuration
      #- ./config/caddy/Caddyfile:/etc/caddy/Caddyfiledocker-com
      - ./docker/app/public:/var/www/app/public:ro
    depends_on:
      - app
    # Run webserver nginx on port 80
    # Feel free to modify depending what port is already occupied
    ports:
      - "80:80"
      #- "443:443"
    networks:
      - invoiceninja
    extra_hosts:
      - "in5.localhost:192.168.0.124" #host and ip
  app:
    env_file: env
    restart: always
    volumes:
      - ./config/php/php.ini:/usr/local/etc/php/php.ini
      - ./config/php/php-cli.ini:/usr/local/etc/php/php-cli.ini
    depends_on:
      - db
    networks:
      - invoiceninja
    extra_hosts:
  db:
    image: mysql:8
#    When running on ARM64 use MariaDB instead of MySQL
#    image: mariadb:10.4
#    For auto DB backups comment out image and use the build block below
#    build:
#      context: ./config/mysql
    ports:
      - "3305:3306"
    restart: always
    env_file: env
    volumes:
      - ./docker/mysql/data:/var/lib/mysql:rw,delegated
      # remove comments for next 4 lines if you want auto sql backups
      #- ./docker/mysql/bak:/backups:rw
      #- ./config/mysql/backup-script:/etc/cron.daily/daily:ro
      #- ./config/mysql/backup-script:/etc/cron.weekly/weekly:ro
      #- ./config/mysql/backup-script:/etc/cron.monthly/monthly:ro
    networks:
      - invoiceninja
    extra_hosts:
  # THIS IS ONLY A VALID CONFIGURATION FOR IN 4. DO NOT USE FOR IN 5.
  # cron:
  #   image: invoiceninja/invoiceninja:alpine-4
  #   volumes:
      # - ./docker/app/public:/var/www/app/public:rw,delegated
      # - ./docker/app/storage:/var/www/app/storage:rw,delegated
      # - ./docker/app/public/logo:/var/www/app/public/logo:rw,delegated
  #   entrypoint: |
  #     /bin/sh -c 'sh -s <<EOF
  #     trap "break;exit" SIGHUP SIGINT SIGTERM
  #     sleep 300s
  #     while /bin/true; do
  #       ./artisan ninja:send-invoices
  #       ./artisan ninja:send-reminders
  #       sleep 1d
  #     done
  #     EOF'
  #   networks:
  #     - invoiceninja
networks:
  invoiceninja:
In general you just need to copy the database using mysqldump and the .env file to migrate.
I did the migration today. It’s easy. In general it’s how @hillel said: Just make a mysql-dump of your database and fill out the important things in the docker-compose.yml- and in the (.)env-file.
But be careful! I, for myself made some extra-changes – for example within the nginx-reverse-proxy-settings for SSL and for a client-portal-domain which differs from the domain i log in with. In case you made some as well, you should be carefull when migrating. There could be some differences to your old docker-environment.
And by the way: If you should not be able to see your company-logo, check the APP_URL-variable in the .env-file.
Have to admit that migration can possibly cause corruption within PDF-attachments! Beware and make a backup! Result for me was that I could not send any invoice, quote or whatever e-Mail anymore! Whyever it worked for a few moments before.
Referring to this: EMails for Invoice Reminders Not Sent
