How can i migrate from v4 selfhosted to v5 hosted?
is it necessary to take a pro subscription before migrating as I have more than 20 existing customers on my selfhosted v4?
I see this within my selfhosted v4:
__
"In order to start the migration, we need to know where do you want to migrate.
Self-hosted
By choosing the ‘self-hosted’, you are the one in charge of servers."
__
I cant select the option to migrate to hosted, only selfhosted.
Thanks for your reply!
Regards!
Sven Pelgrims
February 13, 2023, 7:49pm
Which version of v4 are you using?
If you have more than 20 clients then you will need a paid plan.
February 13, 2023, 7:53pm
4
Ok, you’ll need to update to the latest v4 to use the migration.
ok, will do! If the update is done, can i select migrate to hosted version?
February 13, 2023, 7:56pm
6
With the latest v4 it’s possible to migrate from selfhosted to hosted, I’m not sure it it’s presented as an option in the UI though.
Ok, i will let you know. Thanks for the very quick response!
Hi, just updated v4 and migrated succesfull. I did purchase the pro plan before migration (check invoice 01-27558) but after the migration it says i’m back on the free plan??
February 15, 2023, 3:52am
9
Please send an email to [email protected] and we’ll correct it
