When my customers open the invoice link in microsoft Edge, the logo in the header of the invoice doesn’t show up. It works fine in Microsoft Explorer though. Chrome works fine as well.
I tested this on a few different computers and they all did the same thing in Edge.
Is there a way to fix that?
I tried switching the logo to Jpeg but still the same issue, the logo doesn’t show up when viewed in Edge. I also tried this on a few different invoice templates, but the same problem happens.
It would be less of an issue, but the default browser on Windows 10 is Edge. So this could effect a lot of clients…
Ok, I just got this to work on Edge by converting the logo image into a dataURL format.
In the custom design settings, I inserted the crazy long dataURL code into the spot for $accountLogo
I’m not sure this is the right way to fix it, but it works.
Is there anything wrong with doing it like this? or should it be done differntly
