Version <v5.11.17>
Environment <Docker - TrueNas Scale 24.10>
Hi:
I am not sure if this is the correct forum for this question, but I am trying to do a mysqldump of the mariadb database in my invoice ninja app. If I shell into the mariadb container, it says I do not have the rights to create the backup file.
If I try to do it as a cron job using
sudo docker exec 0cad5bab45e5 mysqldump -u ninja -pninja ninja > backup.sql
I get the error - sh: 1: cannot create backup.sql: Read-only file system
I am not sure if it is related but the maria-db container has lots of warnings saying
[Warning] Access denied for user ‘root’@‘127.0.0.1’ (using password: YES)
Otherwise the app seems to running OK.
Any help with this is much appreciated.
