I used v4 for many years trouble free and after trying unsuccessfully in the past to upgrade, I decided to finally try again and move to v5.
I am on a sharedhosting service. php 8.1. So it is hard for me to run things from a command line.
My version of InvoiceNinja is v5.7.62-C145 (it says that is the latest)
What works: Critical features work so that at least Clients can view the pdf of the invoice in the email so at least I can continue to use the product while I fix the issues.
What does not work:
- client portal gives them a 404 error
- pdf buttons do not work for preview, nor download, etc. BUT when I am creating the invoice I can see the pdf display on the bottom of the window! Also, since the clients can view the attached pdf, pdf generation is working partially.
- If I click on print the invoice, view, or download the pdf, I get an error (404: Route does not exist) and the dynamic status line keeps moving and I cant save the invoice nor do much…
- the yellow warning flag on the bottom left of the window indicates the cron job is not configured, but it seems to be configured correctly so I am not sure why the warning won’t go away.
If I could get the client portal and pdf working I would be very happy. The cron job and auto sending invoices is not a big deal.
